View the DvR backbone entries (redistributed host routes) learned from all Controllers in all DvR domains.
You can view DvR backbone entries only on a Controller. Viewing backbone entries does not apply to a Leaf node.
Ensure that you enable DvR globally on the node.
- Select DVR.
- Select the Backbone Entries tab.
- Optional: To filter the rows based on the specific criteria, select Filter.
Backbone Entries Field Descriptions
Use the data in the following table to use the Backbone Entries tab.
Name |
Description |
IpAddrType |
Specifies the address type of the DvR backbone host (IPv4 remote ARP). |
IpAddr |
Specifies the IPv4 address of the DvR backbone host. |
L3Isid |
Specifies the Layer 3 I-SID of the DvR backbone host. |
DomainId |
Specifies the domain ID of the DvR backbone host. |
EcmpIndex |
Specifies the ECMP index of the DvR backbone host. |
HostMacAddr |
Specifies the MAC address of DvR backbone host. |
L2Isid |
Specifies the Layer 2 I-SID of the DvR backbone host. |
AdvControllerName |
Specifies the host name of the advertising Controller. |
AdvController |
Specifies the host MAC address of the advertising Controller. |
NextHopName |
Specifies the host name of the next hop Backbone host in the DvR route. |
NextHopMac |
Specifies the MAC address of the next hop Backbone host in the DvR route. |
